brake problem, no fluid to one caliber help!
Old Mar 28, 2010 | 02:44 PM
crip's Avatar
Default brake problem, no fluid to one caliber help!
the car is a 92 hatch, has integra front and rear brakes 40/40prop. i put new rotors and pads on rear, and steel braid lines all the way around. then i started to bleed all for corners and when i got to the drivers rear i got nothing. no fluild, no air just nothing. while the brakes where being pumped i could hold the hardine and feel something like a pumping sensation in the line but nothing coming out line. i traced the line from the prop valve all the way to the rear caliber and no pinched line or obstruction that i can see. is it possible the prop valve is not pumping to the driver rear? all other corners pressure is fine and they bleed normal. any help would be great, thanks
Old Mar 29, 2010 | 12:37 PM
crip's Avatar
Default Re: brake problem, no fluid to one caliber help!
no insight?
Old Mar 29, 2010 | 05:53 PM
crip's Avatar
Old Mar 29, 2010 | 06:05 PM
Jockone's Avatar
Is the bleed nipple/screw just cracked open or have you tried taking it all the way out?
Sometimes the holes for the fluid to come out get clogged with $^it,if not that try working your way from the back to the front of that line undoing the joins untill you get fluid and that should tell you where the problem is.
Old Mar 29, 2010 | 06:35 PM
98civdx's Avatar
Master Detailer
having you tried blowing the line out? it might just have crap in it.
Old Mar 30, 2010 | 05:21 PM
crip's Avatar
thats what i am going to try, i am also going to undo that line at the prop valve and pump the brake to make sure fluid is coming out, also need to get a blow gun tip that i can somewhat fit to blow air thru the line, thanks for the input.
Old Mar 30, 2010 | 08:14 PM
PhatFactory's Avatar
Did you also replaced the brake booster from the teg??
Old Mar 31, 2010 | 02:34 PM
crip's Avatar
yes replaced booster, mc, prop valve, and front & rear brake set ups with new russell's lines
Old Mar 31, 2010 | 09:34 PM
cyrusli's Avatar
i'd check to see if your caliper is seizing and then bleed the system completely, spending more time on that one caliper making sure when you bleed, get fluid out of that line first before you bleed the other ones.
Old Apr 1, 2010 | 03:32 PM
Any luck yet? I'm 100% sure I know what the problem is..... Let me know if it's still stuck.
Old Apr 1, 2010 | 05:14 PM
98civdx's Avatar
Master Detailer
^what is it?
Baby99EX
Suspension & Brakes
11
May 25, 2018 08:08 AM
nycpatron
Sep 6, 2016 06:58 AM
bay.kid
May 8, 2013 10:00 PM
WhiteOnRice
Suspension & Brakes
10
Nov 3, 2012 03:45 AM
MechEng
May 14, 2012 03:23 PM
