replaced tank, now im not getting fuel.
Old Mar 28, 2010 | 01:35 PM
bnuk013's Avatar
Default replaced tank, now im not getting fuel.
My tank had a lot of rust and was starting to leak when I filled it so I finally bit the bullet and put a new one on. The project went pretty well, everything is hooked back up and I've got enough gas to register on the gauge, but now it won't start. I thought it through several times and I'm positive I hooked everything up, and I can hear the pump going when I turn the key. I loosened the pressure tap bolt in the top of the fuel filter where it will usually squirts fuel and nothing comes out, even after letting the pump run a whole bunch.
This is a 93 DX, any ideas?
Old Mar 28, 2010 | 06:24 PM
bnuk013's Avatar
Default Re: replaced tank, now im not getting fuel.
~~SOLVED~~
The sock filter on the end of the pump had gotten caught in the old tank. once I fished it out and put it back on the pump the car started up no problem.
Pena-bb4-620U.M
Oct 28, 2012 07:17 PM
pr3lude1992
Feb 18, 2009 06:30 PM
sc0braj
Oct 4, 2008 02:15 PM
EKSedAndy
Nov 12, 2007 10:22 AM
trooper0641
24
Dec 12, 2004 10:09 PM
