Sub Box Size for Spare Tire area????
Old Mar 28, 2010 | 12:39 PM
mikeycivic's Avatar
Default Sub Box Size for Spare Tire area????
I want to make a box for my 12"jl sub that will fit in the spare tire wheel well of my 00 coupe. Anyone know what size box I need to make to fit in there. I want to have flush mounted sub. Need some help/suggestions.
Old Mar 28, 2010 | 02:30 PM
fcm's Avatar
fcm
Old Fart
Default Re: Sub Box Size for Spare Tire area????
Which JL audio 12", they make a few of them.
Fiberglass with a MDF baffle and bracing would "use up" the least amount of room, main measurement will be subs mounting depth, [height of baffle], your looking at 1.250-1.375 cuft (net) depending on model of sub, easily flushed into spare tire well. 94
Old Mar 28, 2010 | 02:44 PM
mikeycivic's Avatar
jl 12" subs are 1.25 cu ft. at least mine is
its a 12w3v2
Old Mar 29, 2010 | 05:30 AM
mikeycivic's Avatar
tt
Old Mar 29, 2010 | 11:40 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I used packing peanuts to do mine and most fiberglass enclosures. Hell while your at it might as well throw a pair in there, lol. Trust me you will thank me later.
Now that I think about it 4 might be a better option. Its a easy task. I sure you can do it.
Old Mar 29, 2010 | 11:42 AM
mikeycivic's Avatar
um my 1 12" is just fine. Im over all the BASS days lol
Old Mar 29, 2010 | 05:13 PM
fcm's Avatar
fcm
Old Fart
1.25 cuft for a 12W3v2 and 300W RMS to drive it. 94
http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Old Mar 29, 2010 | 05:26 PM
mikeycivic's Avatar
lol i have that pdf too, so more info on building a box
Old Mar 29, 2010 | 05:58 PM
El Civ's Avatar
Can you fiberglass?
Old Mar 30, 2010 | 05:32 AM
mikeycivic's Avatar
well I suppose I could but I have never done it
Old Mar 30, 2010 | 05:43 AM
fcm's Avatar
fcm
Old Fart
You need to start by determining the volume of your spare tire well.
I use water, I line the well with plastic and fill it with water, I have a 20 liter bucket marked in 1 liter increments, I install jack stands to keep car level, once I have the well filled and have recorded the amount of water I put in, [liters] I convert that to cubic feet, use a siphon to get rid of the water, the last of it will come out with the plastic.
Now you have an very accurate volume of the spare tire well and are able to estimate how much of the well you need for the box.
I block off the rear part of well, [6" or so, depending on the box volume I need] for storage, using MDF, cut, sanded and notched to fit the well, then fiberglass the rest of the box, 1/4" of fiberglass is equivalent to 1" of MDF, I use 1" MDF for the baffle. 94
Old Mar 31, 2010 | 04:38 PM
mikeycivic's Avatar
that seems way more involved than I wanted to get, but I guess thats my only option?
downtime1
Audio / Security / Video
Oct 6, 2018 03:05 PM
urnotfast
Feb 1, 2006 04:34 PM
noob with an RS
Dec 9, 2004 10:49 AM
phreakmang
11
Jul 14, 2004 06:11 AM
redrex
Jun 15, 2004 06:53 PM
