Front LCAs
i have a 94 civic dx and my bushing are out... so im a head to the junkyard, and i want to put a front sway bar i know i need the si/ex or teg arm... but what part do i just need the straight bar or the A-part.... and if i change the part will i need an alignment
The 99-00 Si/SiR lca is huge and longer compared to what you need. Get the arm from an ex if you want the sway bar...as far as new bushings go....just buy new or low mile used arm I'd say.....all the bushings are included.
you just need the a-arm, i used the front brakes, and lower control arms from my Si (Canada, Ex USDM) on my 92 vx hatch, no need to an alignment, unless your messing with your struts/upper control arms
Sly_Samba
May 3, 2009 03:49 PM
'99 HB Hank
Aug 22, 2002 07:55 PM
