Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
need info on changing throttle bodies
Old Mar 28, 2010 | 09:33 AM
egblack94's Avatar
Default need info on changing throttle bodies
whats up guys i have a 07 civic si 4dr i hate the drive by-wire on it i know skunk 2 and a bunch of other companies make t/b but what happens when i change it? what happens to the connector for the drive by-wire?
Old Mar 29, 2010 | 06:10 AM
Willie Mack's Avatar
Default Re: need info on changing throttle bodies
The DBW is a sensor. if you change to the cable you may have to ground out the sensor wire so as to not throw of the ECU. Now assuming your adventure for the DBW fix is the talk of a person who wants to mod the ride, I say go for flashpro. It helps a lot with the throttle response and as you mod, it can do so much more for you. Just a lil something to think about.
Old Mar 30, 2010 | 02:11 PM
egblack94's Avatar
thank dude appreciate it...isnt flash pro like 7-800 bucks?
Old Mar 30, 2010 | 03:39 PM
Heres a lil trick. Buy a Cobb Access Port of somebody for cheap as hell. Then take advantage of the Hondata Trade deal and give them the Cobb and $130. If you play it right, you may spend about 4-5 hundred.
Old Mar 30, 2010 | 04:25 PM
K5^'s Avatar
K5^
Brand New
Quoted.
There are many supporters and vendors of Hondata on this forum, including myself. You're better off discussing schemes like this via PM instead of displaying it to the whole forum.
Old Mar 30, 2010 | 04:41 PM
Originally Posted by K5^
Quoted.
OK
1000_miles
Dec 20, 2006 03:28 PM
GsRwHiTe
Mar 22, 2004 03:08 PM
fishman
Aug 25, 2002 07:54 PM
accord_ex90
May 2, 2002 08:17 AM
