V6 Crankshaft Pulley Bolt
Decided to start a new thread on this.
Filled the No. 4 cylinder with rope since the pulley holder was bending/not working.
The rope works great.
Now the socket is skipping/rounding off the bolt.
What the f..k!
It is a new 12 point socket.
Will a 6 point work at this point?
What the f..k!
The trick is to have the 6 point socket on the bolt and the breaker bar resting on the frame near the headlight. The engine spins counter clockwise so when you start the car it should break the bolt loose.
Then use a pulley holding tool to tighten the bolt back up to 180lbs.
-B
-B
nate_o
26
Apr 23, 2024 09:28 PM
Chev
20
Jul 21, 2018 08:14 PM
awjuhl
14
Jan 22, 2012 04:43 PM
