is my axel shot? what should i do please help!!!!!
Old Mar 27, 2010 | 03:21 PM
95coupeb's Avatar
Icon3 is my axel shot? what should i do please help!!!!!
y1 lsd tranny with a b16a idk what happened noticed i was leaking tranny fluid and just was looking at it and found this.
noticed bracket was not attached, and axel was slightly out.
is my axel shot? and what would i say i need in order to order correct bolts, for that bracket
also for when its fixed how do i tell if the tranny fluid is at the right level. once again i have a y1lsd tranny attached to a b16a
Old Mar 27, 2010 | 04:46 PM
95coupeb's Avatar
Default Re: is my axel shot? what should i do please help!!!!!
bump...anyone out there that can help?
Old Mar 27, 2010 | 05:36 PM
BryanM.'s Avatar
Resident Gearhead
Yeah, the half (intermediate) shaft bracket came loose. Somehow all 3 of the 14mm bolts popped out.
The axle is probably fine, the tranny end of the half shaft might be chewed up though.
You can get the bolts from any B-series engine, a B18A1 or B18B1 would probably be the easiest to find.
Old Mar 27, 2010 | 05:58 PM
BryanM.'s Avatar
Resident Gearhead
I would drain and refill the tranny. When was the last time it got done anyway?
I use the tube and funnel method to fill it throught the 17mm bolt in the upper right of the pic below but...
...here is how B18C5-EH2 does it,
Originally Posted by B18C5-EH2
Locate the drain plug and use a 3/8'' driver with no socket and remive the drain plug:
Here's where the trick comes in that will save you headahces. Usually you have to ghetto-rig a funnel and tube to fill the tranny in the fill hole which really sucks. My method is really easy.
1. Remove the vent cap found near the front/top of your tranny:
2. Find the Speed sensor located on the topside of the very back of your tranny:
3. Take the 10mm on a big-*** extension and remove the bolt (it's the orangish one in my pic - yours probably won't be oragnish):
4. Now see that big-*** hole left after you move the speed sensor out of the way? Use the funnel and fill through that hole! By the way, no need to unplug the speed sensor - just move it out of the way.
5. Fill up with specified amount or until fluid dribbles from the fill hole below.
6. Put the speed sensor back in, tighten up the fill plug (if you loosened it).
7. Replace the vent cap and you're done!
Now put your wheel back on, torque the lugs to spec with a torque wrench and take your car for a test drive!
The full, awesome write up:
https://honda-tech.com/forums/showth...highlight=axle
Old Mar 27, 2010 | 06:10 PM
BryanM.'s Avatar
Resident Gearhead
I looked at it again, and I see the the half shaft bracket is broken. I would ge another one. I outlined where it broke in red in the pic below:
Old Mar 28, 2010 | 02:54 AM
95coupeb's Avatar
there was only one bolt remaining. and the tranny fluid was done back a couple weeks before christmas.
Old Mar 28, 2010 | 04:33 AM
BryanM.'s Avatar
Resident Gearhead
Did you read my other post?
Old Mar 28, 2010 | 06:05 AM
95coupeb's Avatar
ya i read it. thanks. whats teh capacity of the y1 lsd do you know? iv looked and never found a full legitiment answer. and to replace the half shaft bracket do i need to pull the whole axel out of the car??
Old Mar 28, 2010 | 06:29 AM
BryanM.'s Avatar
Resident Gearhead
1.9 quarts at the most.
Yes, and if it was me I would just get another half shaft.
Old Mar 28, 2010 | 06:32 AM
Jimster480's Avatar
I believe its 1.9QT just like the D series.
And filling it from the Speed sensor hole is way easier. Thats what I do.
Old Mar 28, 2010 | 12:44 PM
95coupeb's Avatar
really only 1.9 quarts?
Old Mar 28, 2010 | 02:28 PM
Jimster480's Avatar
yes
Old Mar 28, 2010 | 02:46 PM
95coupeb's Avatar
and go through the speed sensor hole? and is there a way to clean the speed sensor?
Old Mar 29, 2010 | 07:18 AM
TurboTron's Avatar
Saw this info the other day...going to use your method today...Thank You!!!
Old Apr 2, 2010 | 04:09 PM
95coupeb's Avatar
i know this is gonna sound stupid. but what exactly does the bracket attach to? block? frame? what?
Old Apr 2, 2010 | 04:13 PM
BryanM.'s Avatar
Resident Gearhead
To the block.
Old Apr 2, 2010 | 04:14 PM
95coupeb's Avatar
anything dangerous to be around in there? cause i may have to drill out some bolts i havnt gotten a great look at the other to holes to see if they broke or just backed out/previous owner never put them in.
Old Apr 6, 2010 | 09:57 AM
95coupeb's Avatar
so if two of the parts where its mounted onto the block are broken? is there anyway i can replace those? or am i that ****ed and need a new block? the bracket is only being held in by one bolt. the bottom one. if you dont understand what im saying then i will take pictures later tonight when my sister comes home with the camera and post them. and if i do need a new block. anyone got a b16a block, in the CT area??
Old Apr 6, 2010 | 02:36 PM
BryanM.'s Avatar
Resident Gearhead
No one else wants to post in this thread?
Can't be repalced, they are cast into the block. Doubt it's worth trying to fix.
There is a company in Jersy that sells them. Don't know if they are legit or not.
FastReligion
Jun 6, 2006 02:04 PM
Mario.
Mar 29, 2005 07:19 AM
silverCRXTC
May 19, 2003 05:30 PM
hb_racer
Jan 13, 2002 03:49 PM
