AC HELP!
hey everyone,
okay well, i have a 93 civic and when i got it, it was missing the evaporator. also the rest of the AC (inside the engine bay) was after market, probably for the r12 to R134a conversion.
i got an evaporator from a 94 civic and i got some AC lines made that i was missing. when i turn the AC on though, the fan for the condenser and the compressor does not turn on. any ideas on this?
when i put the evaporator in i noticed that the plug on the evap is different than the plug i have in the harness.
(this is not my stuff, these are pics that i found on the interwebz)
here's what the plug on the evap looks like:
and here's what the plug on the harness looks like:
(the plug circled is what i have, the plug with the X is some other plug that that person had on his Canadian car.)
the questions i have are: what is this for? and, is there an adapter i can use? or, not the ideal way to do it, i know, but; how can i mickey mouse this to get this to work.
Thank you soooo much everyone!
okay i figured out that that is the thermostat. so i just jumped that together.
when i turn the ac on it still doesn't turn on though. but i found that the compressor and condenser fan work when i connect it directly to the battery. so i'm guessing that the relays that the compressor and the fan go into are bad.
any way i can test if the relay is bad? and what else can cause this to not work?
CB1F-M-12V-H15 is the relay. if anyone has any of these laying around, i would love to take if off your hands :-D
well, seems like it already IS mickey moused. the relays that were in the car were aftermarket WITH and extra pin, so i dont even know how that worked. so i guess for now imma jump it for now until i can afford the 44 dollar relays... both of them... or find some at the junk yard ORRRR if someone has them laying around... hint hint... haha
EJ1 wilcox
21
Jan 7, 2008 11:49 AM
