Really Odd Brake/Idle Problem
So I have a 95 EG hatch DX. Yesterday I was working on it, changed the thermostat, and then replaced the left rear brake line because it was leaking (I have discs). Anyway after the thermostat was changed, I started the car and everything was fine. Then I went to do the brake line and bleed the breaks, started the car, and the brake pedal didnt have any pressure, and my idle kept jumping up and down between 1 and 2k, but was fine when I started it after the thermostat install. Also, when the engine is off and I bleed the brakes I can get a solid pedal feel but after its started, I barely have any pressure, I can still stop the car but the brake travel is really long, yet when I turn off the motor it pumps up just fine. I don't know if the two problems are related, while they wouldn't seem to be, they both appeared after I changed the brake line. Any help anyone can provide would be helpful.
I bled the coolant again, and it fixed the idle problem. Still have the brake problem though, and IDK if its relevant but at idle its below 1k, and when I press and release the brake it jumps up to 1000 and then back down.
boarding2008
Jul 4, 2010 12:08 PM
