Poping out of gear MAYBE.....
Old Mar 27, 2010 | 10:38 AM
k_lude's Avatar
Default Poping out of gear MAYBE.....
everytime i change gears on the car while i hold the clutch down or if i brake or let go of the gas the shifter moves a little with my hand barely touching i notice...no i dont move it..thanks anyone who can help
Old Mar 27, 2010 | 01:00 PM
b18bye's Avatar
Default Re: Poping out of gear MAYBE.....
So does it just move a little or does it pop out of gear???
if it just moves a little it may just be your motor mounts are beat ,
Old Mar 28, 2010 | 02:00 AM
k_lude's Avatar
There's actually alot of vibration from the shifter also vibration a little on the clutch and gas pedal I was leaning towards a tranny mount and maybe the shift linkage but not sure also
Old Mar 28, 2010 | 08:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You car has a rigid shift linkage connected to the transmission housing. When you open and close the throttle, the engine/transmission moves, thus causing the shifter to move.
Completely normal behavior.
Old Mar 28, 2010 | 05:13 PM
k_lude's Avatar
i just looked under the car and the shift linkage that connects to the tranny to the shifter were that boot is from tranny to shifter link is busted wat can happen?thanks for the insite so far guys...
hondaPINK
17
May 17, 2006 06:09 PM
90dxhatchback
Jun 30, 2005 02:45 AM
ru2slo
Apr 5, 2004 08:45 PM
dose
16
Oct 5, 2002 07:40 AM
Fobstylez
Sep 10, 2002 02:12 PM
