Where is the 1998 Honda Accord Main Relay?
Your picture doesn't show it. It should be by itself, attached to a bracket. You should be able to see the electrical plug connector from the bottom going into the main relay (not like the relays shown in your picture). The main relay should be somewhat larger than the relays shown in your picture.
See this link: http://techauto.awardspace.com/mainrelaydefine.html
Also see attached parts detail image.
Why are you changing the main relay? I have the same car (98 4-cly 193k) and have never had problems with the main relay. I have had to change the ignition switch twice though.
Everyone made this much more confusing than need be. The main relay for this accord is underneath the driver side kick panel in the leftside corner of the "nook." Its a small black or gray box.
Its sorta tight, and hard to get to. Just some patience & small hands are needed.
romeoz24_2000
Aug 12, 2008 04:03 AM
but thanks for the extra info
