Crap fuel economy
Old Mar 27, 2010 | 04:46 AM
chris0628's Avatar
Default Crap fuel economy
hi guys... here goes my story......
Got a Civic 2000 (Exi - D15Z4 Engine) Conventional A/T & it had done around 70k miles on it.... as soon as i got the car, i changed the timing belt, a bad engine mount, shocks, bushes, boots....etc....
i noticed that from the first day the fuel econ was very bad... 18-19 miles per gallon in city running... the route i take had no traffic @ all.... & highway or out station (we call it) fuel econ is abt 24-25 miles per gallon....
This is a A/T but it can't be that bad right... so i got the throttle body cleaned, injectors cleaned, fuel system cleaned, timing properly adjusted, distributor properly adjusted, spark plugs changed (not that the old ones were bad)....distributor cap is ok, wires r fine, no misses @ all, idle is stable & most of the time i see water droplets coming out of the exhaust... (so that's very good )....
i do not drive fast either....
finally got the agents to plug in the scanner & check... they said the injector pulse (open time) is too long even @ idle speed...
this ECU cannot be re-programmed
Also the agent & everyone i checked said that since this is a model imported BRAND NEW into the country by the agent, it does not have an O2 Sensor...
What can i do ??? pls help
tightDA8
Jul 3, 2019 08:16 PM
afnan
Jan 5, 2014 03:57 AM
dlmoore101
Jul 12, 2012 05:21 PM
johnny090881
Jun 7, 2009 10:56 PM
civicspeed77
May 27, 2003 12:13 PM
