VIPER ALARM KILL SWITCH PROBLEM
hi there, so i have a 2000 civic 4 door.. so i just bought the car and when i bought it, the guy said that there was a viper alarm to it, however, the alarm does not work so then he used it as a kill switch. so when i bought it, for him to start it he had to press this button which was a kill switch i suppose and then he turned the ignition and then it started.. and so i tried it and at the time it also turned on and i did it a couple of times.. so 4 hours later after buying the car.. i try to start it up.. but now it doesn't start??? any ideas??? during the day it was about 55 degrees and by night it dropped to mid 30's.. any clues? its not clicking.. could it be the starter or could it be because of the VIPER alarm? but it was just recently running? i dont know.. some one help!!
thanks
thanks
The starter isn't clicking or the alarm brain isn't clicking? I assume you can get in to your car... if so, when you open the door does the light come on as it should?
michelvaradero
Audio / Security / Video
Nov 3, 2008 05:01 AM
