Thrust washers on a D16Z6
Old Mar 26, 2010 | 08:41 AM
1LowSol's Avatar
Default Thrust washers on a D16Z6
Okay so i was in my garage last night changing my Rings and bearings... I turned the crank and the Thrust washers fell out. I have searched and checked both of my books.. I have a pretty good idea of were they go.. But before i seal up my motor i want to make 100% sure and since i have never messed with those before.. Does anyone have a good diagram or something of some source to show me or explain to me were they go for sure please. Thanks in advance!
Old Mar 26, 2010 | 09:10 AM
ChokolAwt's Avatar
Default Re: Thrust washers on a D16Z6
best i can give ya buddy. part #10. if you remove the crank you'll see indentations on the block side, cylinder 2, on either side of the main bearing. have the grooves pointing outwards.
Old Mar 26, 2010 | 09:14 AM
1LowSol's Avatar
I Slid them back in between the crank with the grooves pointing outwards.. I just don't think that there gonna stay. unless the main bearing gridle holds them in place? Does that do it? I just wanna make sure.. thanks for the help.
Old Mar 26, 2010 | 09:19 AM
xide_12's Avatar
Yea the main cap definatly holds them in place, you should be all set.
And if you put some oil/assembly lube on them it will hold them in place way better when you put the crankshaft on.
Old Mar 26, 2010 | 09:24 AM
1LowSol's Avatar
Awesome, thanks guys.
Old Mar 26, 2010 | 09:25 AM
ChokolAwt's Avatar
+1 a little bit of oil on the block side of the thrust washers will hold them in place till you can get everything bolted up.
Element3488
Oct 3, 2012 07:17 PM
Jdm03
Aug 24, 2011 04:56 PM
ozzyman
Jan 26, 2010 12:13 PM
b20cvc2nr
Feb 7, 2008 07:13 PM
xxmastermindxx
May 6, 2007 09:17 AM
