Turbo oil feed when using a thermostatic sandwich plate?
Old Mar 26, 2010 | 08:22 AM
DreTec's Avatar
Icon2 Turbo oil feed when using a thermostatic sandwich plate?
Hi guys!
Right, oil cooler kit is going on the car. I'll be using a Mocal thermostatic sandwich plate, I have a few inline adaptors between the cooler and the plate for oil temp and oil pressure senders, but I just realised... I can't run the turbo feed from here, because the thermostat on the sandwich plate won't open until I hit a certain temp which means no oil for the turbo until I'm up to temp!!!
I have also seen it's advised not to feed the turbo directly from the back of the block, you have to use filtered oil.
Is there a way around this? Not sure what to do now!
Thanks
Dan
Old Mar 26, 2010 | 08:28 AM
NonovUrbizniz's Avatar
Loved
Default Re: Turbo oil feed when using a thermostatic sandwich plate?
You can run an inline filter off the back of the block.
Old Mar 26, 2010 | 05:48 PM
TEAM ASSASSIN SI's Avatar
there are other places you can tap in to.
Old Mar 30, 2010 | 03:01 AM
DreTec's Avatar
Thanks! Don't know why I didn't think of that!
I'm now tempted into getting an inline thermostat so at least I can tap the oil feed betweent he filter and the inline thermo.
Thanks again.
bigsnorlax
Jan 18, 2015 12:12 PM
GT500FTW
Feb 13, 2013 10:40 AM
ImPuLsIvE
Jun 14, 2008 05:38 PM
creechrr
Jan 2, 2007 02:04 PM
Spade
Mar 15, 2002 06:36 AM
