Painting suspension components
I was curious to know what kind of paint would be recommended for painting OEM suspension components?
I picked up some knuckles, rear LCA's with sway bar and end links from a 94 Intgera that grew up in Chicago and the paint has peeled off on most and there is light surface rust. I will be putting them in the media blasting cabinet to strip them down but want to use a good paint.
Also, I am buying some Koni's and would like to lower the profile of the car by painting these black as well, and tips or suggestions?
I wasn't sure if I should post this here or the painting section.
Best regards,
Best regards,
I used POR15 on all my arms in the past. Currently I am having my newest project sandblasted and powdercoated. If you go with the POR15 route, you'll want to use a finishing paint over the POR15 - it's not UV protected. I used a simple semi-gloss black spray.
Brushed on POR15:
Finished with spray:
No problems to report either way - POR15 or powdercoating. If it's a matter of cleaning the powdercoat will be easier to maintain as the finish is smoother and dirt/dust wipes away easier. The downside is the extra cost.
Brushed on POR15:
powdercoating will hold up much better plus it is much easier to clean and maintain. If you do paint it, use regular 2 stage car paint with a clear coat.
WhiteOnRice
27
Mar 4, 2007 07:22 PM
miksew
May 30, 2006 02:07 AM
