O2 Sensor
if you're staring at the engine from the front of the car, the first one should be right in the center of the manifold before the catalytic converter. the second one you can access from underneath the car.
i've never heard of anyone cleaning an o2 sensor with carb cleaner and having it work again. if it's throwing a code, you should just replace it.
One mounted to the side of the bottom of the exhaust manifold.
One mounted on the rear of the catalytic converter.
I believe this should cover the D15Z4 (it covers the D14A4, which is similar in component location). I checked the D14Z2 to make sure they didn't change anything for 2000 and the locations are the same. (The D14A4 and D14Z2 are 1.4i engines used in the UK.)
hybrid90
Apr 23, 2012 02:47 PM
mrwokn
Mar 20, 2011 08:44 AM
aw2000
Nov 19, 2008 08:19 AM
