What should my gsr do on a compression test?
My tech did one last week and he said that it cranked at 210 p.s.i., but he said the all-data said that it should crank at 270 p.s.i., but he added that that seems high enough to possibly be a typo. Which is right? 270 p.s.i. seems insane!
As I recall, 270 is the highest possible value but is never really seen. Thus, it is used so that if you have a coolant/oil leak and are getting 320psi, you will know something is wrong. Most are in that 190-230 range as previously stated....usually around 195 from my past experience. I think mine w/ JDM ITR pistons was pumping out around 230.
My All stock JDM B18C is right at 215-220psi per hole. Remember, consistency is the key to your engines shape, not necessarily the max number on a compression test. I think a healthy motor should all be within ~2%
engine hot, distributor unhooked, throttle body open,
gauges are also all over the map. some read higher than others. i actually own one that's more of a bent valve tested than accurate. tested a newer corvette the other day with 18k miles. said 140psi in one of the cylinders lol. obviously a lil low.
compression numbers will also differ depending on your elevation too. Like here in Reno, Nv my b20z did 185-195 across but in sacramento it did 220-230 across
JConto
12
Feb 23, 2010 10:01 AM
locote
Jan 8, 2007 03:30 PM
needforvtec
Oct 9, 2006 08:18 PM
