Honda S2000 Honda S2000
Buddy Club N+ Adjustment
Old Mar 25, 2010 | 07:20 PM
young-richie's Avatar
No Sales Forums
Default Buddy Club N+ Adjustment
Hey guys I just tired to lower my car more on my bcs. So I have the rear shocks as low as possible. The red nipple that is on the bottom of the shock is literly 2mm away from my lower controll arm so I cannot go any lower. So at that height my car still has a bit of a wheel gap and i have 17s with a 40 series tire. I called Albert at BC and he said it could be that my bushings are siezed and it's not allowing the suspention to go all the way down...? One side of my car is lower than the other and i have them adjusted at the same point on my shocks. So I'm not sure what to do about this. Any help would be appreated! thanks
Old Mar 25, 2010 | 08:13 PM
tle05's Avatar
Default Re: Buddy Club N+ Adjustment
I'm kind of in the same situation as you! Although I still have a bit of thread left on my coils, they're both adjusted to the same point but my driver side sits lower than the passenger side. Mine is an 05 with 16k miles.
Old Mar 26, 2010 | 11:07 AM
White Smoke's Avatar
i my honda
Global Mod
Jack up the rear of the car, put it on stands and loosen up all of your control arm bolts. While on the stands with the bolts lose jack up the wheels still they slightly lift up the car. Then tighten up all your control arm bolts.
Repeat for the front…
ricehero
Suspension & Brakes
16
Sep 20, 2005 04:38 AM
madhatter07
Suspension & Brakes
Aug 9, 2005 10:55 AM
Slvr_CRX
Apr 24, 2004 04:22 PM
Pengo
Jan 20, 2003 06:41 AM
thesource
Oct 17, 2001 10:32 AM
