Suspension & Brakes Theory, alignment, spring rates....
Help I know NOTHING!
Old Mar 25, 2010 | 01:50 PM
rgp4chip's Avatar
TRIAL USER
Default Help I know NOTHING!
Okay loved Hondas forever.... Bought an 09 ACCORD Lowered it with an eibach kit. 1 1/2''... camber is all messed up. I have already wore through one set of tires. Should I get a camber kit (700$)? or get coil overs? I heard coil overs are better but I'm not sure... Please help!!
Old Mar 25, 2010 | 01:55 PM
singlecamslamed's Avatar
Stage 3 CLINGER!
Default Re: Help I know NOTHING!
Coilovers are just a different way of lowering the car. they wont help
your camber at all.
Usually if you only lower your car 1.5" like you said, just get the toe alligned.
Your tires will last plently long enough. Toe is what really jacks up tires, not camber.
If you still go through tires, get a camber kit. im sure you can find one for a lot
cheaper than $700.
Old Mar 25, 2010 | 09:17 PM
alphalanos's Avatar
+1. Get an alignment with toe zeroed out or very close. Camber just leave it, its should be fairly close to the same setting on each side.
blackccoupe
Suspension & Brakes
12
Oct 18, 2009 03:53 PM
OdysseyHF
Nov 29, 2003 07:25 AM
ilikemyaccord
Aug 13, 2003 10:37 AM
toooslow
May 7, 2003 12:38 PM
InfamousRS
Feb 14, 2002 07:31 AM
