Fan Switch or CTS?
Ok guys I'm confused and frustrated with my car! So it started overheating yesterday. My fans are not coming on. So I disconnected what I thought was the CTS under the dizzy connecting to the lower radiator hose and jumped it and the fan turns on. So I went to Autozone and got the CTS brought it home unhooked what I thought was the CTS and they are different. One is skinny with a post at the end and the one I pulled out of the car is fat and flat at the end that plugs into the car. So I go to checkers and they manually looked through all their sensors and found my part. Took it home hooked it up and car is still overheating. So after searching online everywhere I could I think what I replaced was the fan switch.
I don't have any pics of what it was that I replaced. Does anyone have pics of the two different things and can you explain to me where both are located? Pics would help immensely.
Oh yeah its a 93 Integra sedan 1.8. B18A1
Thanks
Thanks
Depending, there are up to 3 CTS. The one post plug is for the gauge cluster, the one in front of that is for the fans I believe and the one by the thermostat (on the coolant neck under the IM) is for the ECU. Atleast I believe that is how they all work....and it does vary on certain years as I recall.
So how do you narrow it down to the one thats not working? The fan works when I jump the connector that plugs into the flat one (fan switch I believe) but when I replaced that switch it still doesn't turn the fan on
