PCV valve pops out easy
Old Mar 25, 2010 | 11:59 AM
quickster's Avatar
Default PCV valve pops out easy
I changed my PCV valve recently in one of the steps of troubleshooting why my car idles bad. Oil was on one of my plugs when i switched them out and i switched out the pcv valve, problem solved, ive driven 2k miles with the new plugs and have been checking that one for oil every 250 miles or so and no oil.
anyway, my pcv valve pops out with little to no strain at all, it just seems kinda loose. should i have replaced the grommet that it goes into? should it be easy to pop out? could that cause idle problems if there is a leak there?
Old Mar 25, 2010 | 12:11 PM
RICKSAUTOMOTIVE's Avatar
Default Re: PCV valve pops out easy
yes try replacing the grommet. the pcv valve should pop out easily with nothing more that a little pull but it shouldnt pop out in its own
Old Mar 25, 2010 | 12:32 PM
quickster's Avatar
its kind of inbetween that. it seems to pop out a little too easy when warm. the old one took a good tug. is it better to replace grommets with the engine cold or warm?
Old Mar 25, 2010 | 06:01 PM
fleetw00d's Avatar
The grommet will be more flexible when warm (don't burn yourself though).
95B18Teggy
Jun 11, 2014 08:46 PM
sevenfc
Dec 5, 2008 03:03 PM
Layziebtnh055
Apr 11, 2004 07:41 AM
jdmspoonitr
Sep 17, 2003 05:09 PM
1.8T_EG
Nov 19, 2002 03:05 AM
