95 eg cx - starting problem
Old Mar 25, 2010 | 11:22 AM
B18Chonda's Avatar
Default 95 eg cx - starting problem
My boys eg is having problems turning on sometimes. The battery, alternator, and starter are straight. Won't crank, do not hear anything. After another try or a couple mins, it will then turn on. Have an on/off motor cut off switch, but it's working like its suppose to. ls with gsr tranny. Any suggestions?
Thank you.
Old Mar 25, 2010 | 12:56 PM
Mot Gnuoy's Avatar
Default Re: 95 eg cx - starting problem
Sounds like a bad ground. Remove them all and clean the ground points with a wire brush. If they look bad replace the cable.
EGee Eddie
Oct 14, 2013 05:46 PM
Midnight EG6
Oct 10, 2013 11:57 AM
Bikes&Bowties
Jan 19, 2012 05:49 AM
