Dizzy Question
Old Mar 25, 2010 | 11:12 AM
Theperfectsin's Avatar
Default Dizzy Question
I was wondering if i can use an obd2 dizzy in my obd0-obd1 swap.I know its possible to keep an obd2 dizzy when converting down to obd1 but i just don't know if i can skip over. The only reason i want to use it is because i happen to be given one.I understand there are crank signal inputs and such and don't know if i can just exclude them. Any input would be ausome
Old Mar 25, 2010 | 11:55 AM
FEDONV8's Avatar
Default Re: Dizzy Question
ok what motor is in da car and my i ask why obd2 when it just right to go obd1
Old Mar 25, 2010 | 12:12 PM
I am running a d16y8 and am currently converting to obd1 from obd0 but i don't have an obd1 dizzy and was hoping to use an obd2 dizzy instead.
Old Mar 26, 2010 | 06:16 AM
Icon3 Re: Dizzy Question
Any input??? i need this figured out asap, track opens soon
Old Mar 26, 2010 | 06:20 AM
JustAnotherRex's Avatar
Search function is your friend.
Old Mar 26, 2010 | 07:04 AM
alx_90ef's Avatar
obd-2 will work with obd-1 just convert your pluga
Old Mar 26, 2010 | 07:33 AM
thanks guys,i guess i didn't look hard enough i just found conversion from obd0-1 and obd 2 to 1 but never thought they are pretty much the same i just have to match harness wires up sorry about that.
Old Mar 26, 2010 | 07:49 AM
JDM8o9's Avatar
swap dizzy internals
Old Mar 26, 2010 | 08:06 AM
Why would i swap the internals? i would end up with an obd 0 dizzy when i need obd1?
Old Mar 26, 2010 | 08:43 AM
91CR-XSiR's Avatar
totally unecessary to go away from obd1 especially if its in a Da or Ef chassis....good luck with that tho, i hope it works out
Old Mar 26, 2010 | 12:09 PM
i am converting to obd1, just need a dizzy and the one i happen to have is obd2 and i was hoping to use this one
grodzef9
Jun 19, 2008 10:32 AM
BoogiepopJDM
Jun 16, 2007 02:51 PM
blakh
Aug 15, 2006 07:52 PM
michael_antoi
Sep 23, 2005 08:05 PM
ekb16
Feb 15, 2005 06:51 AM
