CEL: Check EGR
I've got a CEL on and after checking the code, it is regarding the EGR valve. How major of a problem is this? I havent had much chance to look into it. And the car has been running no different than before. Gas mileage is the same as well. Thanks in advance for any advice.
the egr valve is only an issue in states where emmissions are an issue. in south carolina you dont have to worry about it. in california, you have major worries but only when you have to smog your car. it basically reduces oxides of nitogen emissions (NOx) by recirculating exhaust gas through the egr valve and the intake manifold into the combustion chambers. you eg valve is probably stuck and your egr valve lift sensor is detecting that the egr valve is not lifting enough and sending you the CEL code
Thanks, that helps put my mind a bit more at ease. So I don't have much to be concerned with, correct? It's nothing that will be detrimental to the engine over time, right?
afstvx
Feb 15, 2008 12:04 AM
Linh.
Dec 10, 2005 10:03 AM
