having issues with motor swap
i am currently doing a gsr in to a 98 ex. i am having problems aligning the motor. i have the sides mounted but the rear is giving an issue. any suggestions? i have a rear ctr/si bracket or i think i do any help would be great as to i want to finish it asap. below is a picture of my rear bracket.
Does it connect properly to the engine itself? Where exactly are you having issues? Also, what driver-side mount are you using? Just eyeballing it, it *LOOKS* like it should.
I've attached the part diagram for the 99-00 Civic SI mounts. Does your bracket have anything stamped on it?
Sean
Sean
not that i know of. i'll be pulling the rear motor mount back out and see what the problem is. 99 si driver side mount. just rear alignment is problem.
GrimeyAssLos
11
Feb 27, 2012 09:56 AM
AzntaggeR
Feb 14, 2004 07:31 PM
crxhybrid1320
Apr 20, 2003 07:00 PM
