Strange D-Series Combo Question
Old Mar 25, 2010 | 12:01 AM
HiroshimaScreamer's Avatar
Icon2 Strange D-Series Combo Question
I have been searching all over and can't see any previous posts of such an idea(I'm not completely surprised tho).
I have a mate that has just run all the bearings on his ZC. The rings are also toast, as well as the oil pump & head gasket. He has a SOHC (D16A7) motor at home which has bent valves. He is in a serious financial dilema & now wants to see if we can make a temp plan to get the car running.
My question is:
Would one be able to use the SOHC bottom end in conjunction with the DOHC ZC head?
If so, what would the implications of such a strange matching have.
Obviously power will be somewhat lower due to the different pistons, but at this point I don't think that will be a concern.
Old Mar 25, 2010 | 01:03 AM
DCRB's Avatar
Default Re: Strange D-Series Combo Question
afaik the head bolt locations are different, atleast on the zc head with a d15/d16a6/z6/y7 and 8... so my guess would be the same. perhaps his best bet would be to see if the valves from the DOHC fit into the sohc? just a thought.
Old Mar 25, 2010 | 01:19 AM
24TEN's Avatar
PHANTOM MENACE
If that D16A7 is equivalent to a standard D16 here stateside then the answer is the standard "it will not bolt up" response. As DCRB has said the head bolt locations are not entirely the same between the SOHC and DOHC engines. Having said that, if your buddy is willing to invest into some machine work the DOHC head can be modified to fit the SOHC block.
Old Mar 25, 2010 | 04:47 AM
~sp33~'s Avatar
EFB055
There's also a coolant passage that doesn't line up 100%.
Old Mar 25, 2010 | 09:21 AM
4gen5thtime's Avatar
So in short answer NO IT WILL NOT WORK. He'd be better off buying a cheap single cam for now, used from a trusted source.
If he has tons of money at disposal, he could make it work and probably be one of a hand full to do it.
Old Mar 26, 2010 | 02:42 AM
Thanks a lot for the info guys!!! I have spoken to him about this and explained what you have said. He has decided that he would rather rebuild the ZC than go through the issue of trying to match the SOHC & DOHC together.
Unfortunately, it's his daily drive so he'll be taking a loan to get it up & running asap.
Old Mar 26, 2010 | 02:53 AM
DCRB's Avatar
dang that's too bad. lucky though it shouldn't cost him too much money
97bootleg
11
Jun 18, 2008 02:18 PM
bcphatchback
Oct 9, 2004 07:14 PM
teamrushhatch
Aug 31, 2003 06:36 PM
Hulkbuster
Feb 8, 2003 11:08 AM
