KNock sensor delete ?? ECU decision
Old Mar 24, 2010 | 08:15 PM
trevek10's Avatar
Default KNock sensor delete ?? ECU decision
hey guys wanted to ask you if anyone has got an ecu from http://www.phearable.net/ and what was the experience.. i think they are a seller on here so im sure someone has bought from them/ buddy of mine recommended it
second: my knock sensor broke (buddy broke) when putting in swap and instead of buying new one put one that he had (claimed to work) and long story short doesn't
was thinking about getting a ecu that would delete and knock and maybe add little performance rather than buying new knock sensor ... what and where have you guys gone to get ecu's any recs?
the motor is a b18c obd1
has hondata intake mani gasket
skunk2 mani
custom intake
stock internals
act pro light fly wheel
and everything else is pretty much stock
Thanks
Old Mar 24, 2010 | 08:17 PM
trevek10's Avatar
Default Re: KNock sensor delete ?? ECU decision
also has anyone gone here
http://www.xenocron.com/
Old Mar 24, 2010 | 08:48 PM
trevek10's Avatar
bump my own
Old Mar 24, 2010 | 08:51 PM
darkenedsol's Avatar
Bump because I'm wondering about the same thing....
Old Mar 24, 2010 | 09:00 PM
trevek10's Avatar
bump for you wanting to know!
Old Mar 24, 2010 | 09:16 PM
thumper64's Avatar
There's a way to simulate a knock sensor, but considering what it does, I wouldn't. I mean, it's there to protect the motor. It's like pulling seat belts out of your car to save an extra pound of weight.
Old Mar 24, 2010 | 09:50 PM
trevek10's Avatar
i know i didn't want to do that because for the simple reason that the effort into fooling the ecu i could just take the knock sensor out and replace it
as for point two is there a benefit for removing it??why remove it
Old Mar 24, 2010 | 10:18 PM
trevek10's Avatar
Old Mar 25, 2010 | 09:43 AM
trevek10's Avatar
Old Mar 25, 2010 | 10:05 AM
xenocron's Avatar
You can safely eliminate the Knock Sensor in any OBD1 Honda Setup in my opinion...
First, most people worried about this are running Premium Gas, and these motors/ECUs were tuned for 87 anyways, if you are setting off the knock sensor on a stock motor, you have bigger problems.
Second, as soon as you change something about the dynamics of the motor, chassis or anything that will effect the "frequency" of the car...you essential render your knock sensor useless, even picking up false knock when it isnt really there.
Let me know if I can help you out with anything you might need!
Chris
Old Mar 25, 2010 | 07:09 PM
trevek10's Avatar
Chris
thanks chris that answers the question well.. my buddy also rec you guys for the ecu
Old Mar 30, 2010 | 10:54 AM
trevek10's Avatar
ordered thanks chris
trevek10
Engine Management and Tuning
Mar 25, 2010 10:20 PM
h22lude317
May 22, 2009 08:58 PM
Shft@9GSR
Sep 18, 2003 09:43 PM
untitled
Aug 8, 2003 08:03 PM
delslow94
Dec 26, 2002 12:52 PM
