poly bushings in front sway bar d bracket
hey guys, obviously i know the benefit of poly bushings in allot of the suspension components as opposed to the traditional rubber; however, curious if there is any real gain from replacing the oem rubber in the d bracket from a 99 civic si front sway. just in the process of moving everything over to my hatch and just curious about this and if its even worth the $20. thanks in advance.
Probably. Despite marketing claims, poly DOES NOT last longer than rubber. Both will dry rot eventually, but it happens to poly much sooner. And when it does, it basically disintegrates into dust.
This is my old poly shifter bushing after only 4-5 years, and this is a bushing that doesn't move or have anything moving in it. Imagine how one with a sway bar twisting around inside of it will wear.
You won't see me ever using poly bushings again if I can help it. I have HardRace hard rubber bushings in my garage waiting to be installed.
yeah those are the bushing i used in replacing the front except i didnt have the front lca fork bushings in the set i snagged... is there a distributor on HT?
deviant1
Jan 25, 2005 07:18 AM
