spark plugs!!!!!!!!!!! help
Old Mar 24, 2010 | 04:30 PM
jdm mini me's Avatar
Icon2 spark plugs!!!!!!!!!!! help
ok i have a 89 honda crx and my spark plugs keep getting oil on them help
Old Mar 24, 2010 | 04:40 PM
D16SiHatch's Avatar
Default Re: spark plugs!!!!!!!!!!! help
the top part of the plug, or the bottom in the combustion chamber?
if top, replace spark plug tube seals. if bottom, could be leaky valve seals or oil control rings on the pistons.
Old Mar 24, 2010 | 08:51 PM
projekt90ef's Avatar
first, replace your valve cover gasket. cheap, easy to do, and nothing wrong with a new gasket. i had the same problem...even oil on the threads, but its all better now. do that before you blame it on the piston rings. i recommend replacing the gasket, plug seals, AND new sparkplugs...check it after a few days.
Old Mar 24, 2010 | 08:58 PM
The-obd0-one's Avatar
And dnt forget to look up the proper tourqe specs on those head studs when puting the head bak on and if the studs are old and streched it's best to replace them or else it will not maintain a good cell on the blok
Old Mar 24, 2010 | 09:00 PM
D16SiHatch's Avatar
why the hell would he pull the head, who said anything about that?
Old Mar 24, 2010 | 09:03 PM
Oops I read it rong thought he said head gasket sry man
Old Mar 25, 2010 | 01:56 AM
ok i fix my problem lol thanks it was my valve cover gasket / plug seals thanks evey one
Old Mar 25, 2010 | 02:37 AM
buru07's Avatar
LOL! X2-D16SiHatch... Removing the head will not be neccesary! Unless you plan to change your oil control rings, and take your whole enigine apart... & changing your valve cover gasket, will not fix your problem of oil in the spark plugs! Although when changing you spark plug tube seals, you should definately replace the valve cover gasket while your in there!... Read post #2... This is cut and dry. Its either 1 or the other!(hopefully not your rings, for your sake!) Good Job SiHatch!
P.S. If its your valve seals, then yes, also remove the head, and do a complete rebuild on the head....ex. check for warps, cracks,any visable damage... Get new valve seals,valves(if you like,or if nessesary. depending on your purposes for the car or your budget. Last time i check valves for my f22 bout $12 a piece...X16...Roughly $200 For OEM valves. Probably more now-a-days. I dont know.) Machine for smoothness & slap back together with some new gaskets! ... Good luck!
Old Mar 25, 2010 | 04:16 AM
beansandrice's Avatar
He already fixed it no need to be an asshat.
Old Mar 25, 2010 | 08:57 PM
buru07's Avatar
it was 40 minutes difference, between posts at 3 in the morning. I was buzzed and probably still writing my input when he had posted that it was fixed... Dumbass, go eat urself
Old Mar 25, 2010 | 09:04 PM
Echo 6's Avatar
dude lol... yea do the valve cover gasket thing & get back to us
Acura_DreamiN
Oct 26, 2010 07:23 PM
skaternak
Oct 2, 2008 10:32 PM
SuicideSlide
Feb 14, 2007 04:53 AM
Dorksk8tr3
Aug 18, 2005 09:46 AM
civicxspower
Jun 5, 2005 12:19 AM
