JRSC cam questions
Since I can't make heads or tales of the 500+ page jrsc thread I thought I would just make a new post. In my b16, would gsr cams with a set of adjustable cam gears net greater hp than the stock b16 cams with a jrsc setup? I have read through the thread and understand that adjustable cam gears usually attribute to a healthy gain in the mid-range but never did see anything about gsr cams. Anyways some help would be appreciated.
Thanks!
Thanks!
Thanks!
Thanks!
https://honda-tech.com/forums/showth...2556604&page=4
http://www.ftlracing.com/tech/honda/JRSC.html
thanks for the help man! I really appreciate the response. really? b16 intake cams on the intake and exhaust? that just sounds funky. I don't know much about the cam profiles to judge but you're right it does sound wierd. I'm going to try and find a gsr intake and ctr exahaust now. thanks fro the help!
no problem! if this where 3 weaks ago i would of had 2 01'' spec itr ex cams that i sold lol!! just get the ctr ex cam cause its the closest to the o1'' spec itr ex cam!
The 00/01 US ITR intake cam is a new addition. The markings are almost that of a CTR intake cam. I've checked the VTEC lobe and it's oh-so very close to the spec of a CTR cam. This cam has it's own spec, meaning it's not like like the 96-99 US ITR int. cam. This 00/01 cam will produce a tad bit more power than previous years...
http://www.ff-squad.com/tech/temp/VtecCams.htm
