car starts then dies?
Old Mar 24, 2010 | 01:04 PM
Rickdogg's Avatar
Icon2 car starts then dies?
my 90 ls has been giving me some problems it will run fine when i first start it in the morning but when i stop and shut it off when im done driving and go to start it back up it will idle real rough and then shut off after i do this a couple of times and give it some gas it runs fine i was thinking it was the timing but i checked it and its right on the red mark anyone know wat the problem could be?
Old Mar 25, 2010 | 06:43 AM
95 integra's Avatar
Default Re: car starts then dies?
Main Relay?
Old Mar 25, 2010 | 09:44 AM
delsolproblems's Avatar
Do you have any problems after the engine fully warms up but before you stop the car?
Old Mar 25, 2010 | 10:00 AM
TheAsian's Avatar
Sounds like you have a fuel pressure issue to me. Can you give a little more detail like how long you drive engine temp, how long it sits, if you start the car and let it run rough will it die or dose it smooth itself out
Old Mar 27, 2010 | 08:30 AM
Rickdogg's Avatar
anytime after it warms up, the temp is normal, right after i shut it off it does it but if i let it cool down it will start up fine, when it runs rough it will die unless i give it gas or put it in gear
Old Mar 27, 2010 | 08:33 AM
Rickdogg's Avatar
no it runs fine after i get it started just when i go to restart it
Old Mar 27, 2010 | 08:55 AM
You're probably looking at either a clogged filter or an ignition problem when the car heats up. Try checking the spark at all four wires and either check or change the air and fuel filters. If the ignition doesn't check out, have the ICM and coil tested at a parts store.
Bones82
Honda Civic (2001 - 2005)
Oct 14, 2010 07:15 PM
lyzer227
Feb 7, 2009 12:02 PM
busyychild
May 11, 2007 05:13 AM
Chris93Si
Aug 1, 2006 11:12 AM
bladesoxy
Jan 17, 2005 07:21 PM
