1998 RHD gsr sedan
THINGS CAN BE REMOVED AND THE CAR COULD BE SOLD CHEAPER MAKE N OFFER BUT I WONT PART ANYTHIN OUT UNLESS THE SHELL SELLS
puttting it out there see what happens im always lookin to build something new if not il jus keep it but jus seeing what happens i guess
98 integra 4dr gsr shell
95 sir-g RHD conv
oem jdm front (SIDE MARKER HOLES WERE FILLED WIT BONDO CAN BE EASILY BE CUT BAK OUT)
ctr 5lug wit jdm itr wheels (new tires)
omni power 1 pieces
omni control arms
skunk2 camber kit
meagan tie bar
full race traction bars
4dr itr-front and rear seats
jdm itr cluster,steering wheel, all 4 door panels (front door panels have tweeters holes cut wit alpine type r tweeters and speakers rear door panels have some marks from wen they were shipped
OEM RHD integra floor mats
motor .
b18b1 ls block
aebs sleeved (84mm)
cp pistons
eagle big bolt rods
all new bearings hone resurface and assembled by rjt machine
arp head studs
gsr head
ferrea titanium retainers and dual springs
ferrea 1mm oversized flat top valves
00 itr cams
polished jg edlbrock manifold
680cc injectors
cast manifold
xs power waste gate
t3 70trim turbo
3in down pipe
greddy intercooler
2.5bar map
will be running and tuned on aem EMS on how many lbs the injectors can handle unless i get bigger ones
$13,000 no part out
text (603) 845 7390 or pms will be replied
95 sir-g RHD conv
omni power 1 pieces
omni control arms
skunk2 camber kit
meagan tie bar
motor .
b18b1 ls block
aebs sleeved (84mm)
cp pistons
eagle big bolt rods
arp head studs
gsr head
00 itr cams
680cc injectors
cast manifold
xs power waste gate
t3 70trim turbo
3in down pipe
greddy intercooler
2.5bar map
$13,000 no part out
