Integra GSR 1999 Black Coupe
Price drop to 4,800
Im open to trades also, and the car must be clean and not a pos
All my cars are very well taken care of, and I kept serivice up to date
Cars got 111k and some change
Black on black
Service done
Under body is rust free!
New Timing belt OEM
New water pump OEM
New Plugs
New tires(Dunlop snow and ice tires)
New O2 sensor
Sync oil
New oem air filter
valve adjustment
Valve cover gasket
Cooling system has been flushed
New upper radiator hose
New power slot rotors
New Hawk HP brake pads
New trans fluid
New passanger side wheel bearing
New alum half core racing radiator
S2000 cooling fan
Currently being added
New oem alternator
New cap n rotor
Wires
Passanger side window motor
Front 02 sensor
Enjo precision products Urethane engine/ motor mount kit
Fast Lane Wheel height shifter thats counter balanced with Skunk2 shift ****
Omni Master Slave cyclinder(Hard to find)
Some scratchs and dings on the car.
No clear coat fadding, paint shines up
Drivers side qaurter has one inch rust, ive been using touch up paint to make it looks presentable
Blades have some curb rash and some peal
Needs
Shift boot
Shift brezel
HAVC the temp adjust broke so its stuck on hot(Its cold anyways)
AC was taken out because it was going to be a turbo car
Rear bumper could use paint
Head unit is ghetto rigged
Over all a nice daily driver
Im open to whatever, this is just a feeler
http://s970.photobucket.com/albums/a...urrent=037.jpg
Black on black
Service done
New Timing belt OEM
New water pump OEM
New Plugs
New O2 sensor
Sync oil
New oem air filter
valve adjustment
Valve cover gasket
New trans fluid
S2000 cooling fan
New oem alternator
New cap n rotor
Wires
Front 02 sensor
Needs
Shift boot
Shift brezel
http://milwaukee.craigslist.org/cto/1655890783.html ill throw in some gsr blades and gsr rear disk conversion
