Oil light. HELPPP!!!
Old Mar 24, 2010 | 09:06 AM
JaysonDC2's Avatar
Default Oil light. HELPPP!!!
Ok since i got this car my oil light never came on when i turn the ignition to ON position. i thought it was the bulb in the cluster but it was fine. so today i took a look at the oil pressure sensor at the back of the block by an oil filter and saw a wire from the sensor is cut and i couldnt find the other end that was cut. So now im stuck!! idk what i should do. and is it only 1wire there? HELP ME out people! i need my oil light working so id know when my oil pressure drops.
Old Mar 24, 2010 | 09:15 AM
Acuronda_SloTeg's Avatar
Default Re: Oil light. HELPPP!!!
its a single wire. look around the area of the loom where the injector harness and alternator plugs come out. it should be there somewhere, you might have to cut the loom open a little. alot of idiots cut wires like idiots to fix random lights they always have on
Old Mar 24, 2010 | 09:17 AM
JaysonDC2's Avatar
and i also noticed this gray plug hanging around next to the alternator. can anyone tell me what this gray plug is for and where its supposed to go in? it has black and red wires.
Old Mar 24, 2010 | 09:21 AM
is your iac hooked up? how about iat and evap purge valve that mounts the back of the manifold. and it could even be the crank position sensor but i dont remember exactly what it looks like
JaysonDC2's Avatar
thanks. ill try to look for it again when it stops raining. if i cant find the other end i guess im screw.
Old Mar 24, 2010 | 09:23 AM
its there, i recommend disconnecting your injectors (and all other plugs on the mani), alternator, and o2 sensor and bring that part of the harness around to the tranny side so you can get a real good look at it
Old Mar 24, 2010 | 09:37 AM
JaysonDC2's Avatar
yea everything looked connected the last time i look at it i was tryna find where it would plug in too theyre short wires like 3inches. btw i forgot to mention i have a skunk2 IM!
Old Mar 24, 2010 | 09:39 AM
power steering sensor? lol. i know its usually sittin really low. if you still got power steerin then look to see if that green plug on the main line is disconnected
Old Mar 24, 2010 | 09:44 AM
JaysonDC2's Avatar
lol power steering works fine. but like i said ill take a good look at everything again when it stops raining lol. it should be somewhere close to that plug because the wires arent that long
Old Mar 24, 2010 | 10:02 AM
JaysonDC2's Avatar
so if i find the other end of the oil sensor wire, just rewire/connect it back and my oil light should be working right?
Old Mar 24, 2010 | 12:10 PM
JaysonDC2's Avatar
i think i found that 1 wire but not sure if thats the one and it seems not long enough. its too cold out i dont wanna do it now. plus everything seems in the way idk how im gon connect it back. or do i have to get under the car and remove the oil filter so thered be more space to do?
Old Mar 24, 2010 | 12:16 PM
just use a butt connector for a temp fix. if you got steady hands, solder it back together when you get a chance.
Old Mar 24, 2010 | 12:23 PM
JaysonDC2's Avatar
yea but seems theres no room to do it lol things are in the way. maybe i need to extend the wire alil longer than that then use a butt connector.
Old Mar 24, 2010 | 12:28 PM
lol thats where the steady hand comes in place, you would have to have some mad patience to get that one soldered if its short
Old Mar 24, 2010 | 03:04 PM
JaysonDC2's Avatar
bump.. still wanna find out what this plug is for? and where to connect it to?
m3dia_lab
Feb 5, 2007 01:20 PM
EsQueue
Jun 19, 2005 06:44 PM
dbailey
11
Dec 28, 2004 02:24 PM
stripes777
Mar 26, 2004 05:37 AM
st0nedstoopid
Aug 19, 2003 06:43 PM
