B series turbo part out, assorted DA parts etc etc
Going a different route with my engine setup so i'm parting out a lot of stuff.
Parts will need to be picked up at The Horsepower Connection (4019 NE 6th Ave, Ft Lauderdale FL 33334) or buyer pays shipping.
The TIAL BOV and WG are not for sale...
I'm only selling the items listed below.
2000 Civic Si B16 head...comes with cam caps, lma's, aftermarket valve springs, titanium retainers (im not 100% sure which brand they are) - $400
1989 1st gen B16 head...comes with cam caps, lma's, JG race engineering ported, valve job, head milled...needs to be cleaned up but functions fine - $350
B series valve cover completely shaved and painted silver - $50
90-91 Integra B series Innovative mounts PENDING
90-93 Integra B series Innovative hydro to cable conversion w/ hydro tranny mount $200
Neptune RTP board w/ pwm boost control solenoid + fittings - $350
socketed Honda P06 ECU with vtec conversion - $125
Rywire obd0 to obd1 conversion harness - $50
B series turbo manifold...accepts T3 or T4 turbos has Tial 44mm wastegate flange - $400
Intercooler + 2.5" alum turbo piping for 90-93 Integra with flange for Tial 50mm BOV - $200
RPM services 66mm B series throttle body - $75
Skunk2 Pro Series B16 intake manifold, very good shape + custom throttle cable bracket - $200
Golden Eagle B20/VTEC conversion oil sandwich, oil feed line, cometic b20/vtec 84.5mm hg, oil feed head fitting, head locating dowels - $200
ARP LS/VTEC head studs $50
Eagle B18/B20 H beam rods - $200
Wiseco 81mm pistons for turbo application, some nicks in the dome but work perfectly - $150
2 B18/B20 cranks - $100 a piece
JG Race engineering modified 81.5mm B17 block with welded in block guard - $200
B series oil pan (does not fit GSR/ITR) with fitting for turbo oil return - $40
Misc b series parts...crank pullies, oil pumps, gsr water pumps, timing belts - just ask
Blox 4 bar map sensor SOLD
CP 84.5mm pistons for turbo application, very good shape SOLD
Skunk2 tuner series cam gears SOLD
AEM B series fuel rail with welded on -8 fitting SOLD
RC 1000cc injectors, recently cleaned/flowed by RC SOLD
B series obd1 distributor SOLD
S80 GSR tranny - grinds going into 5th sometimes otherwise perfect SOLD
B series valve cover with two -10 breather fittings shaved and painted wrinkle black SOLD
Golden Eagle sleeved B18a1 block 84.5mm bore needs mains line bored SOLD
I don't have pictures of everything but you get the idea...
silver shaved valve cover, turbo manifold, piping
intercooler, turbo piping etc
84.5mm sleeved block, 84.5mm CP pistons
skunk2 pro series intake, aem fuel rail
dylthomas
Aug 31, 2016 04:52 PM
hondarat09
Northeast (Sales)
May 6, 2011 06:37 PM
dizzyroc88
Southeast (Sales)
Mar 13, 2006 06:33 PM
