Electrical Issue with Brake Lights
1) When I engage the brakes, the rear lower right tail light glows "low" (only one filament) while the left glows "high" as designed (both filaments).
2) When I turn on the city/parking lights, both sides glow "low" as designed but when I engaged the brakes, the left side glows "high" as designed but the right side doesn't not light up at all.
I checked all the fuses and they are fine. Any suggestions where to start troubleshooting?
I tested the bulb with my 12v power supply and both was able to test both filaments without issue. I also swapped the bulb with the left side which works fine with the same result.
I think the problem is within the bulb socket...
