RPM drops
Old Mar 24, 2010 | 01:16 AM
akces's Avatar
Default RPM drops
DID A COUPLE OF RUNS AND ON THE LAST RACE WHEN I WAS JUST ABOUT TO GO INTO SECOND GEAR THAN RPM DROPS ON ME AND MOTOR WAS STUTTERING SO I SHUT THAT BITCH OFF, ANYONE HAS A CLUE? IM THINKING TIMING JUMP... ANY HELP/SUGGESTION WILL GIVE ME A IDEAS WHAT TO LOOK AT..THANKS
Old Mar 24, 2010 | 01:18 AM
Acuronda_SloTeg's Avatar
Default Re: RACING AND RPM DROPS
dizzy crapped out possibly? timing wont throw your tach off
more info please
Old Mar 24, 2010 | 01:37 AM
akces's Avatar
when i was lining up reving at about 4500 rpm and as i take off and motor gets at around 8000 before getting into 2nd gear rpm drops all the way and motor was stuttering... we tried restarting it. you can hear it crank but wont turn over. i had to towed the car home
Old Mar 24, 2010 | 01:39 AM
akces's Avatar
thanks for the help and looking/reading the threads
Old Mar 24, 2010 | 03:09 AM
yeah that sounds like your dizzy crapped out or possibly main relay, fuel pump, or ecu. check for spark. if it stinks like fuel its dizzy. if it doesnt you might wanna check if the fuel pump is even priming. even check the ground on the coolant thermostat housing and the tranny ground strap to make sure they both have good connection
Old Mar 24, 2010 | 05:28 AM
Steven.'s Avatar
yeah i agree
Old Mar 24, 2010 | 07:19 AM
akces's Avatar
cool thanks
Old Mar 24, 2010 | 09:07 AM
update when you find out results
Old Mar 24, 2010 | 10:07 AM
calboi's Avatar
sounds like dizzy for sure mine did this once
Old Mar 24, 2010 | 03:48 PM
nsxtasy's Avatar
H-T Order of Merit
You need to learn how to use this part of your keyboard:
Old Mar 24, 2010 | 11:09 PM
akces's Avatar
Default Re: RPM drops
Got sparks and compression, i took out the valve cover to take a look inside and flip it over and i see this scrape in the inside of it. it looks like the cams and belt was rubbing on the valve. this really got me thinking about how my timing belt ended up looking like this. I wont find out the problem cause im not a major honda tech, i know the basics of it. Its gonna be a while till my mechanic have time from work but i will sure let you guys know just incase someone goes through this. i hear it can be anything from valve bent to piston rings to timing and feul pump etc...
Old Mar 24, 2010 | 11:18 PM
looks like a bolt dropped in there possibly
H22SHtec
May 5, 2011 02:59 PM
accord-h22
Feb 13, 2007 04:45 PM
blaxican05
Sep 29, 2006 08:23 PM
AzntaggeR
Jun 9, 2005 02:10 AM
Tony Ignatz
17
Oct 14, 2004 01:20 PM
