i need help with my 91 si cluster!
Old Mar 23, 2010 | 10:13 PM
crazy bum's Avatar
Default i need help with my 91 si cluster!
well i bought a 91 civic hb dx it had a 88 - 89 si cluster in it.nothing worked so i bought an 90 - 91 si cluster and only thing that works is the lights in it when i turn it on. could it be because the person i bought it off of messed up the wiring? there was only two plugs i plugged in.if anyone wants to try and help, please do so.
Old Mar 23, 2010 | 11:09 PM
crazy bum's Avatar
Default Re: i need help with my 91 si cluster!
40 views and no help? i found a diagram with pictures and explaining what wires are what.and im gona try to put my 88-89 cluster back in tomaro and rewire it.but i know its still not gona work.what could i do to get my gauges workin? maybe loose wires?
Old Mar 25, 2010 | 01:57 PM
xfastline42x's Avatar
88-89 clusters are differnt from 90-91 clusters. 90-91 clusters have a white box on the back for a blue clip to plug into. 88-89 does not.
Old Mar 25, 2010 | 03:49 PM
jxh_28's Avatar
i have cluster dx off 91. it can plug n play. im asking 25 bucks
Old Mar 25, 2010 | 03:53 PM
beansandrice's Avatar
wtf? I think he wants an Si cluster
Op, You need a cluster that matches your year. 88-89 Si is what you need. You can sell the 90-91 Si cluster and buy an 88-89
Old Mar 25, 2010 | 07:08 PM
crazy bum's Avatar
beansandrice i have both 88-89 and 90-91 si clusters. my 91 hatchback when i bought it came with the 88-89 si cluster in it and it didnt work. so i went to pick up a 90-91 si cluster.only thing that works is the lights inside the cluster and hazards.i found a wiring diagram for both years 88-89 and 90-91 checked the wires in my hb they were correct with the 90-91.i even rewired it all and still didnt work, so im guessing its the wires.
Old Mar 25, 2010 | 09:30 PM
efsleep5's Avatar
88's can only use an 88' cluster as well as an 89' can only use an 89'. as far as 90-91's they're exactly the same. this is for factory wiring of course. u can wire up just about any cluster u like if u wanted to. just get the wiring diagrams and repin or cut n solder the plugs, etc...
Old Mar 25, 2010 | 10:16 PM
crazy bum's Avatar
yah.the diagram i found had 88-89 , 90-91 and the diagram for the 90-91 was exactly how mine was wired up so there isnt a reason for it not to work unless the wires are bad right? i even rewired it and still nothing...an i know this is gona be a stupid question but behind the speedometer that whole does anything go in there? i never messed with clusters before so i have no idea.
Old Mar 26, 2010 | 03:25 AM
efsleep5's Avatar
ya thats the speedo cable, its not a dumb question either, those years r cable driven, before the switched the vss to wire. there should be a a big black cable that runs to the back area of the cluster, it has like a plastic clip to hold it on, it is very noticeable. u could also look in ur engine bay for it to run out of the firewall n straight down into the back n on the top of the tranny, just look staright down by ur throttle body for it.
Old Mar 26, 2010 | 10:46 AM
crazy bum's Avatar
thanks.ill check it out today. when i rewired the wires i was looking for something to fit that hole and i didnt see nothing but ill check for it again.thanks!
Old Mar 26, 2010 | 04:02 PM
crazy bum's Avatar
close this thread.found out my problem.
Old Mar 26, 2010 | 05:54 PM
What was it? Post up so we dont get this thread started like a million times over.
lol
Old Mar 27, 2010 | 09:45 AM
crazy bum's Avatar
okay well its not really long but here i go.the wires that plug into the cluster, i followed those threw to under the dash.they plug into i think the fuse box or by it? i forgot, but i unplugged those and rewired them, plugged them back in, then plugged the cluster back up and its works fine now.lol
Old Mar 28, 2010 | 06:04 AM
efsleep5's Avatar
all good, nobody's perfect, i do this type of work for a living and even i forget that i unplugged something or left something unbolted from time to time
bluestd
Apr 25, 2009 11:16 AM
e jay one
Dec 21, 2006 10:25 AM
SNatCH 1.6
Oct 15, 2006 01:54 AM
Speedfreak
Dec 11, 2002 04:43 PM
88hondahatch
10
Oct 25, 2002 06:39 AM
