h23 questions.
Old Mar 23, 2010 | 08:54 PM
(95EG8)'s Avatar
TRIAL USER
Default h23 questions.
im planning to swap this h23 into my 95 4dr civic. what all from a prelude will bolt on with little or no modification? im talking like axles and such. help?
Old Mar 24, 2010 | 09:01 AM
CivicSpoon's Avatar
Default Re: h23 questions.
There really isn't anything that will bolt on with little to no modification. You need to go look at the links posted in your other thread, everything is already written out for you. All modifications that need to be done for the swap are in there and the axle info is in the 1st & 2nd link (no, complete Prelude axles won't work). For the exhaust manifold and the exhaust, you're probably going to have to cut off pipe from your exhaust and weld on a new flange, or you'll have to add more pipe. The other option is to get an aftermarket exhaust system, and get something of correct length to go in between the header and exhaust; like a cat, a resonator, or a test pipe.
Slomies
Mar 2, 2007 09:30 AM
bwco
Jan 12, 2007 07:35 AM
mxer518
Apr 5, 2005 07:10 AM
AndyD
Jun 22, 2004 11:59 AM
LudeyKrus
Sep 23, 2003 08:50 PM
