97 auto LS fluctuating idle while driving!
Old Mar 23, 2010 | 08:47 PM
lunalink's Avatar
Default 97 auto LS fluctuating idle while driving!
Let me start off by saying thank you guys for any info given to me.
This problem started about 2 days ago, as im driving the idle is @ 3k and it bogs down to 1.5k and doesnt go up until i press on the gas and when it does it has trouble getting passed 2.5k.
Not only that but other times that im driving the rpm's would fluctuate between 2 and 3k wtf!?
It feels as if the throttle cable is getting stuck around 2-3k.
can the tranny have anything to do with this? or injectors?
what would be the best places to start looking into?
Old Mar 24, 2010 | 05:40 AM
Steven.'s Avatar
Default Re: 97 auto LS fluctuating idle while driving!
Can you rev your engine all the way? If no check your distributor.
Old Mar 24, 2010 | 07:47 AM
wastedyouth2542's Avatar
check your tranny fluid
Old Mar 24, 2010 | 11:32 AM
lunalink's Avatar
I can rev it all the way. I'm going to check the fluid when I get home.
Old Mar 26, 2010 | 06:17 PM
lunalink's Avatar
well it started getting worse and i cant pass 3k evn when in park. so does this mean my dizzy is going bad? if i change the coil would that fix it?
Old Mar 26, 2010 | 10:18 PM
vroomvroomparty's Avatar
Does your engine SOUND like its misfiring? If not it could be a clogged fuel filter, fuel line, or Fuel Pressure Regulator. Of course check grounds, and battery voltage. Then go get a timing light and see if your timing is right. If its not that, check your air filter, and then throttle cable. Also check plugs, and then plug wires, all the way to the dizzy. Those are pretty well the main fuel/air related problems, you've probably checked all of this stuff, hope it helps somewhat
Old Mar 26, 2010 | 10:23 PM
lunalink's Avatar
It doesnt sound like its misfiring but as im driving it bogs s bad goes from 3k down to 1k FAST! and takes a while to go back up.
Old Mar 26, 2010 | 11:52 PM
mrdeadman's Avatar
They let me pick
cel?
Old Mar 27, 2010 | 10:19 AM
lunalink's Avatar
^ lol. and SRS but i dont have a reader
Old Apr 16, 2010 | 02:04 PM
lunalink's Avatar
well!
it stopped for a while but came back. i changed out fuel rail and injectors. added tranny fluid and still nothing!
what else should i check for, now it bogs sick under semi-full throttle.
what should be the next thing to check.
btw. changed dist.coil
Old Apr 16, 2010 | 02:09 PM
mrdeadman's Avatar
They let me pick
If you have a check engine light on, go to checker or where ever and borrow their code reader and pull the code.
Old Apr 16, 2010 | 08:48 PM
lunalink's Avatar
thats my next step tomorrow
Old Apr 19, 2010 | 02:19 PM
94dbteg's Avatar
yes my 94 ls auto used to do the same bogging down until i hit over 3k when i first started it up but after that it was fine and still does from time to time. but i lately put a skunk2 intake manifold on and when i took old injectors out i didnt noticed but i broke one of the pins on the injector and it bogged so bad i didn't know what it was until h.t. told me to check those injectors again and sure enough. not really much help but plan on finding out a simalar problem me and you have.
Old Apr 19, 2010 | 02:43 PM
lunalink's Avatar
yeah i already changed the dizzy coil, injectors, and rail. and its still the same. FML.
Old Apr 20, 2010 | 10:12 PM
lunalink's Avatar
well i went to pepboys and the only code its giving is 02 sensor. can that really cause it to drive like this??
Old Apr 21, 2010 | 12:31 PM
mrdeadman's Avatar
They let me pick
Yes.
Old Apr 21, 2010 | 01:50 PM
Spawne32's Avatar
someone really suggested checking the tranny fluid for a misfire?
Old Apr 21, 2010 | 02:26 PM
lunalink's Avatar
lol. damn. it what aftermarket 02 sensor would be ideal to get?
i believe they have 2 of them.
Old Aug 27, 2011 | 04:03 PM
CherryBombCivic's Avatar
mine has kind of the same problem i have 1992 honda civic ex D16 it starts up and everything fine but i drive it around and i cant mash on it for anything if i try the rpms bounce and it seems to take its time shifting its automatic idk wtf is wrong with it can aynone of yall help me out?
00ls1
Apr 2, 2008 07:57 AM
CourtesyBullet
Feb 22, 2008 09:18 PM
Preludepradit
May 5, 2007 07:38 AM
Blackedout97
May 22, 2006 12:06 AM
