HELP!!! ITR 36mm 5 Lug Wheel Bearing Replacement!!!
Old Mar 23, 2010 | 06:58 PM
FRKWOO's Avatar
Default HELP!!! ITR 36mm 5 Lug Wheel Bearing Replacement!!!
i need replacement wheel bearings for my 36mm itr brake conversion and i've heard 97-01 crv wheel bearings will work and i was wondering if this was true and if so does the class of which 97-01 crv matter, ex, ls, 4wd, etc... thanks h-t!
Old Mar 23, 2010 | 07:15 PM
BlueIntegraBoy's Avatar
Default Re: HELP!!! ITR 36mm 5 Lug Wheel Bearing Replacement!!!
44300-S47-008View
BEARING ASSY., HUB (NTN)
Old Mar 23, 2010 | 07:25 PM
FRKWOO's Avatar
so i see thats for the ex class crv so how about the rear wheel bearings i see the ex class crv has read drum brakes?
Old Mar 23, 2010 | 09:15 PM
FRKWOO's Avatar
anyone?
Old Mar 24, 2010 | 11:39 AM
eg6ajk's Avatar
Front = CRV
Rear wheel bearing = 97-01 ITR
Old Mar 24, 2010 | 11:42 AM
K20egcw's Avatar
Originally Posted by eg6ajk
Front = CRV
This!
Old May 3, 2011 | 12:40 PM
1hotredg35's Avatar
back from the dead!!
I just want to verify that for 36mm ITR suspension you can run 97-98 Prelude (base model) axles? (if you have a B series tranny)
Also im guessing to replace the hub, what year crv hub and bearing will work?
Old May 11, 2011 | 05:13 AM
1hotredg35's Avatar
No info?
EGtypeR408
Suspension & Brakes
Dec 17, 2012 07:03 AM
NoLeftTurn
Sep 9, 2009 05:11 PM
boostedsol
Dec 26, 2003 06:26 PM
