Honda S2000 Honda S2000
s2000 ACT Clutch and Flywheel sound PLEASE HELP
Old Mar 23, 2010 | 11:19 AM
MisterMonkey26's Avatar
Default s2000 ACT Clutch and Flywheel sound PLEASE HELP
Alright so over the weekend I installed the ACT street clutch & lightweight flywheel. So I am driving it to do the break in period and I notice a noise. Its almost like a vibrating sound and only comes when the motors in like a mid range RPM and when I let off the gas and let the motor slow down on its own. Its doesnt do it when I am going up through the gears or anything and the clutch shifts awesome. I have done a bit of research and I noticed that some people had posted on s2ki that ACT clutches and flywheels make some kind of noise. I am going to put it up on a lift this afternoon and check and see if maybe its just a heat shield or something is rattling under the car or if the sound is coming from inside the transmisison. I guess really I just wanted to see if anyone else had this kind of problem or sounds.
Old Mar 23, 2010 | 11:22 AM
camoy's Avatar
Default Re: s2000 ACT Clutch and Flywheel sound PLEASE HELP
It could be your disc springs are just vibrating around in the plate. Same thing that causes clutch buzz in these cars.
Old Mar 23, 2010 | 12:53 PM
I was actually thinking the same thing. Is there anyway to check it out just to be safe?
Old Mar 23, 2010 | 01:40 PM
TypeR324's Avatar
I have the ACT clutch, I believe the same one you have and have the exact same issue. It was kind of annoying when I first got it but i'm used to it now.
Old Mar 24, 2010 | 11:28 AM
pdawxman's Avatar
TRIAL USER
I installed a Stage 4 Six Pad Competition Clutch last week and it does the same thing. I here it mostly when I'm in 4th and let off the gas. Goes away when I step on the gas.
Old Mar 24, 2010 | 01:06 PM
SirStig's Avatar
Ya I have the same problem with my Comp 6 puck. No issues with it. I have read that this clutch buzz is common in AP1's
Old Mar 25, 2010 | 06:35 AM
95 integra's Avatar
I have the same problem on my stock S2k....well maybe not the same problem, but I do have alot of tranny/clutch noises.
Old Mar 26, 2010 | 11:11 AM
White Smoke's Avatar
i my honda
Global Mod
I think it's the clutch springs...
Old Mar 26, 2010 | 11:56 AM
dagle's Avatar
clutch chatter is my bet, somewhat normal especially on ACT clutches.
Old Mar 26, 2010 | 02:14 PM
JDogg's Avatar
the noise is from the backlash in the tranny, its normal and most cars do it even with the stock clutch. There is nothing wrong.
different rate springs in the clutch can dampen the noise somewhat but its always going to be there.
d_mina
Feb 3, 2005 12:06 PM
flipp117
May 11, 2004 11:37 AM
Nick248
May 23, 2003 10:00 PM
turbo Si
May 5, 2002 08:44 PM
nfn15037
Oct 29, 2001 02:28 PM
