My 94' Integra Gs-R is losing power!? no Cel lights?? Engine Sounds Normal???
Old Mar 23, 2010 | 07:33 AM
SiCk-Eg's Avatar
TRIAL USER
Default My 94' Integra Gs-R is losing power!? no Cel lights?? Engine Sounds Normal???
Sup Guys, i need help!!! i cant figure out this problem? i just replaced distributer,wires and sparkplugs,also fuel filter! car still feels laggy!! no cel lights show up!!?
Old Mar 23, 2010 | 10:00 AM
mouab18c1's Avatar
Default Re: My 94' Integra Gs-R is losing power!? no Cel lights?? Engine Sounds Normal???
Did you re time your timing with a timing gun after replacing the distributor?
Old Mar 23, 2010 | 11:27 AM
SiCk-Eg's Avatar
TRIAL USER
Well the car was already acting sluggish before I changed the dizzy, same result with the new one!
Old Mar 23, 2010 | 11:41 AM
sixfourkiller's Avatar
well have to do u mean by sluggish whats the car doing. that would better help on finding whats wrong.. is there problem when u shift or when your rpm at high. etc etc...
Old Mar 24, 2010 | 07:31 AM
SiCk-Eg's Avatar
TRIAL USER
The car shows no signs of anything, other that it requires more gas than usual, feel power loss in all rpm ranges! Almost seems like a clogged cat? Vtec works fine still, didn't go into limp mode! Maybe a bad O2 sensor?
Old Mar 24, 2010 | 07:52 AM
dudesitsjdm's Avatar
when you floor it do you feel alot of backpressure on the gas pedal?stock intake or after market is the filter clean? have you cleaned the injectors out? are you running low grade fuel and running reall close to empty alot? im just asking to try and find a soultion.
white.
Dec 7, 2009 05:55 PM
ftrms
May 19, 2009 03:40 PM
01-1254
Jan 7, 2009 07:00 PM
00siLS-V
Oct 25, 2008 10:52 PM
Ehop
11
Feb 11, 2008 10:09 AM
