97' Accord misfiring! Need HELP!
So i checked to see why the check engine light is on using the paper clip method. it translate that cylinder 1 and cylinder 2 are Misfiring or a Random Misfire a condition is present that is creating a cylinder misfire
. how would i know that its actually misfiring and where should i start to fix this problem?
*update i replaced the spark plugs, distributor cap, and ignition coil and the check engine light says its still misfiring. Anyone?!
Do you notice it misfiring? I know when my fuel injector went i was running on 3 cylinders which sounded like a misfire. I could tell as soon as it went something was wrong.
HeresOtis
Nov 10, 2017 01:21 PM
mindslayer84
Jan 4, 2016 07:11 PM
