1998 Civic EX annoying beeps in key position 1
I have a 1998 Civc EX. I just picked it up used because my last car was totalled.
The ignition is labeled 0 1 2 and 3.
0 is off.
1 is accessory usually
2 is ON
3 is start
fairly standard on all cars. for most cars position 1 allows you to turn on parking lights, radio, cigarette lighter
position 2 allows you to adjust power mirrors, turn on the fan, adjust power seats,
position 3 is for starting the car.
but there's something very annoying
I just want to listen to my radio, so I put my car on position 1. but the beeping won't stop. Just to check if i wasn't losing my mind, I put my brother's civic 2006 si and my dad's civic 2001 dx in the same position, and it beeps a few times but turns off.
Again, i just want to use my radio. I don't need the car's ignition to be in position 2 (the ON position). I think it just draws too much power from the battery.
I need to turn off the beeping when my key is in position 1. how do i do this?
0 is off.
2 is ON
3 is start
both!! i've tried it with the door open, inserting the key and turning to 1. the radio does turn on, but the beeping wont stop.
and like normal, i get in the car, close the door. insert the key, turn to 1. radio turns on and the car still beeps.
