b20 ecu
Old Mar 22, 2010 | 07:20 PM
93redeghatch's Avatar
Default b20 ecu
ok i had a ls/vtec before, and it blew on me. Then i swapped an all stock b20b without the vtec head on it without changing the ecu. I think im running on a p06 ecu right now. How do i tell what OBD the b20 is? it would be OBD2 right? and what ecu would make the car run smooth, cause when it idles it seems to bounce around 750-1000rpm range. A p75 would work fine? and what OBD is that? thanks guys.
Old Mar 24, 2010 | 10:44 AM
mach0's Avatar
Default Re: b20 ecu
the b20 should be obd2. But the ecu should be a p75 regardless of the obd..Just make sure if your car is obd2, you get the corresponding step down harness.
Old Mar 24, 2010 | 10:56 AM
DumaDA's Avatar
Default Re: b20 ecu
if you were running a P06 i would think that you're already obd1, so just get the obd1 LS ecu and everything should run fine. I have a 2000 b20b running obd0 with a stock pr4 ecu and it runs fine
Old Mar 24, 2010 | 11:08 AM
Sr420Det's Avatar
Default Re: b20 ecu
or u could just go the chipped route and get a chipped ecu with a stock b20 map that way when u put the head on all ud have to change is the chip.
Old Mar 24, 2010 | 11:16 AM
DumaDA's Avatar
Default Re: b20 ecu
yeah thats something i forgot to ask, do you plan on going b20vtec?
Old Mar 24, 2010 | 11:43 AM
Acuronda_SloTeg's Avatar
Default Re: b20 ecu
dont use the b20 ecu either, its for auto trannys, car wont start. just use a p75. im runnin obd1 ls on my 98 b20. keep hold of your ecu that you have right now so if and when you run vtec, you'll have the ecu for it
Mando562
Nov 20, 2013 05:05 AM
types9091
Oct 18, 2011 05:39 PM
91CRX-T
Apr 28, 2011 06:45 AM
j_wod2000
Feb 13, 2006 04:05 PM
B18PoweredCivic
Mar 14, 2005 09:13 AM
