h22a swap in 4th gen accord
Or if you just got the swap done you might want to check the oil level. That is as high as the ECU will let you run when you are low on oil. Just a thought. The wiring problem is prolly correct but check for the simple fixes first
would an apexi rsm(rev speed meter) or an apexi v-afc (vtec air,fuel control) fix this problem???
check your ECU for codes, find out what is wrong and go from there. also check if all the wiring is done correctly.
