need help
Old Mar 22, 2010 | 12:23 PM
starquestchris's Avatar
TRIAL USER
Default need help
i have a 95 se and just did a tranny and clutch.but when i push the clutch pedal to start the car it just went to the floor.i tried bleeding it but it dosnt build pressure or anything.if u have any ideas.please let me know
Old Mar 22, 2010 | 12:32 PM
TheAsian's Avatar
Default Re: need help
How is your fluid level? look for any leaks in the system check your master and slave
Old Mar 22, 2010 | 12:37 PM
TRIAL USER
fluid is fine i put some in there when i finishes the tranns.cant find a leak either
Old Mar 22, 2010 | 12:40 PM
dudesitsjdm's Avatar
did you pump the clutch as u put in fluid?
Old Mar 22, 2010 | 03:37 PM
BoneSt0ck's Avatar
you could try having someone pump the clutch and then hold it down while you bleed it
Old Mar 22, 2010 | 03:57 PM
mouab18c1's Avatar
Process of pumping a clutch usually takes two: Open your resevoir for the clutch lines fill it up if its empty, have someone pump the clutch pedal numerous times then tell them to hold it all the way down. While they are holding it down you loosen the bleeder on the slave cylinder which the brake fluid will come out. Then tigthen it back down. Once you tighten it back down tell the other person to start pumping again. Repeat this as many times as it takes. Sometimes it will take awhile but just be patient.
Old Mar 23, 2010 | 10:25 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
jdmstyleg
11
Sep 27, 2009 06:16 PM
hondaless
Apr 2, 2009 08:58 AM
honda_racing101
Sep 18, 2007 06:53 PM
924doorEG
Jul 16, 2007 05:31 AM
PatrickGSR94
Dec 8, 2002 06:36 PM
