map sensor
Step one, get obd1 map sensor.
Step two, screw obd1 map sensor onto throttle body,
Step three, unplug obd0 map sensor
Step four, plug that plug into the obd1 map sensor.
Notes: You may have to extend the wires slightly to reach the new sensor.
you can put a obd1 map on a obd0 throttle body? i never seen that. but ya if you got a tb with a map on it all you do is take off the firewall one and plug it into the obd1 map on the tb. you dont need to extend the wires they will reach not much slack but it will reach. and youll have a left over plug that you dont need. i just depin it and stuff it in the loom so it looks cleaner.
no you cant, although i see why you thought that from his response. not sure why he worded it like that.
it wont be hooked up to anything anymore so just remove it from the old map.
should look like this when you're done. i was too lazy to extend the wires, but as you can see they do reach.. for the most part lol.
Yeah you'll need an 0bd1 TB to screw it to.
Make sure you block the vacuum line.
88Hatchy
Jun 1, 2009 10:20 PM
SiMateoAko
Mar 23, 2006 08:22 PM
